We live in West Michigan and we decided to open before the water started warming up. I checked it this morning and after a few 75-80 degree days the temp is 60. The pool held it's water level over the winter which was a relief as we had a small liner cut last year that we repaired just before we closed. Last week in anticipation of pulling the cover off, we put the pump on cover to drain the water. A few hours later I looked out to check it and the pool level was way down! I don't understand why it sucked water out of the pool. It's a brand new solid cover! UGH! We have well water so I really hate to add anymore than I have to, but it is what it is. The water is crystal clear and very little debris in bottom. We do use a water filter on the end of the hose to refill. I'm assuming I will test the water AFTER I get it up to level and the equipment is running? Or do I test it before we refill, and start the equipment to get an accurate reading of the remaining water? I have the TFP pro kit. Next question is that the weather is going to change from 80 today and tomorrow to 35 and rain/snow on Monday and then rain and cool pretty much for the next week, Should I just super chlorinate to keep things clear and run the Pentair VS pump at a low constant speed since it's going to continue to be cold? We will put the mesh leaf cover on to keep spring yuckies from getting into the pool. I'm feeling new all over again! I do every year, even though I've owned an AGP for 30 years! (But I am 63 yo and I have the memory of a gnat now!
I AM new to the TFP method of JUST liquid chlorine, testing everyday and SLAMMING. I will update again with my numbers in the TFP app, but just let me know my steps here! Thanks so much!
