Further down is using polyfill in a bucket or the skimmer to trap and remove the iron.I just briefly read the link you posted about the filtering out the iron, but those methods are preventative and would be used prior to filling correct?
It won't be visible once the FC comes down.just wait for the FC to fall and the the iron will "go back into the solution?" I'm not sure what that means.
Right now it's 'precipitating' out of solution and the chlorine makes it appear green.
OK great. Just checking.I do not add calcium, that is apparently from the fill
Salt is its own entity from FC. I have a SWG that uses electrolicises (?) my salt to produce FC. Without the SWG, you add your own FC with liquid chlorine.Salt is then a replacement for FC? or is it combined use with it?
Enter your start value and target and poolmath will tell you how much to add.And how should I deal with the TA? Muriatic Acid, I know, but how much?
If you'd like to speed it up, maintain PH in the low 7s and aerate to raise the PH, needing to be lowered again. Each round drops the TA some.
Or, just lower the PH anytime its an 8 and let it sort itself out.
