CYA is an even 30! PH is also steady. Bombs away with the liquid chlorine!
Just keep the water movingSo I came back from our weekend vacay and I think my "helper" messed up. When I test my free chlorine, my sample turns red, not pink. I'm showing: FC 31.5, CC 1.5... Shouls I be freaking out?
The water is still cloudy but I can see futher down.
Filter sand?My robotic cleaner is also picking up sand.
As long as you were careful adding sand and didn't break a lateral with the sand or overfill it, it should be okay. But you can try to capture some at the return jet with a nylon or something to see if it looks like the sand you added. It should've been #20 silica pool sand.Still Slamming and have a teal pool.
Holding tight at 14 ppm Free Chlorine & 0 Free Chlorine.
Should be FC be 0?
