fenfumbler
2
Spain
Hoping I haven’t done any damage, draining pool ready for a repaint & I made a stupid mistake.
I’m draining through the floor drain only.
Ran the pool set to waste but forgot to open the waste tap on my pipes after the pump, so I guess a build up of pressures & my big worry is that the buried under the pool pipes may have been damaged! It rang for two or three minutes before I realised my error
What are my chances of the pipe joints being ok, I won’t know if it’s losing water until after the work is done & we refil & I really don’t want to have to dig out the bottom of the pool & patio area if not necessary - thanks so much for any advice
Welcome to TFP.
Did you hear any change in the pump sound indicating the pressure released?
50/50.
More likely a glued joint opened then a pipe broke.
You are in Spain. Are all your pipes scheduled 40 PVC?
You can pressure test the pipe.
