Hi everyone, new to the forum. I have an in-ground pool that i just inherited. Approx. 30k gallons, 35 years old. Most of the equipment is probably 10-20 years old. At the equipment, I have three suction valves. One for skimmer (shallow end at least, which will make more sense if you keep reading), one for spa, and one (presumably) for my main drain. In the pool i have two skimmers (one in the shallow end and one in the deep end) and one drain located at the bottom of the deep end. The skimmer in the shallow end (closer to the pump) has great suction. The spa has good suction. The main drain I'm not so sure about but I believe its working properly from futzing around with the suction valves and watching the air pressure on the filter (D.E.) at the same time. In other words, if I close the skimmer and spa valves but open the third valve, water is still being drawn through the pump to the filter.
Anyway, the skimmer in the deep end of the pool is the problem. It has virtually no suction, no matter what I do with the suction valves. There are two holes in the bottom of each skimmer btw. I live in Las Vegas where it doesn't freeze all that often so I have some hesitancy to think the skimmer in the deep end was closed for winter, but I suppose its possible. Is it possible to "open" (i.e. unseal) the skimmer hole in the deep end skimmer (the one that appears to be intentionally closed at the skimmer itself) so that I can utilize this skimmer instead of only one? Feel free with any questions, I explained it as best I could but I'm sure I missed some info that would be helpful. My previous pool guy told me that the circulation is better with just one skimmer open, along with the main drain". Not sure if he was correct or if he was too lazy to figure out and fix the issue with the nonfunctioning skimmer.
Thoughts? Thanks everyone.
