First time poster. First time pool owner as of one month ago. In-ground pool, about 30,000 gallons.
In my pool, there are 6 returns:
- 1 of them seems larger than the others and doesn't have an eyeball insert. I honestly don't know if it is different than the "normal" returns, but the water flows out of here better than any other return. It is the closest return to the pump.
- 1 of them seems to only return water when the Polaris pump booster valve is opened. I will never use the Polaris pump, so not actually sure whether I should close the valve all the time so this return is rendered inoperable?
- 4 of them seem to be "normal" returns.
Of those 4 normal returns, 3 of them have decent water pressure coming back into the pool when my sand filter is in filter mode and the pump is on.
However, it is the 4th that doesn't have any water pressure that I can feel when placing my hand over the return. This return is the furthest distance from the pump...even though there is another return that works fine about the same distance away, but on the other side of the pool.
What I did to troubleshoot was to turn off the pump, plug up the other 3 normal returns with screw-in plugs, and then turn the pump back on. I thought maybe the dedicated pressure to that troubled return line would potentially spit out any debris and unclog. After doing that, water was coming out of the 4th return just fine! Problem solved...or so I thought.
When I took the plugs off the other 3 returns and put the eyeball inserts back in for normal operation, turned the pump back on, the same problem with the 4th return not having any water pressure came back to life.
So my question is this: Do I just have to live with the fact that that 4th return won't ever have any water pressure? Is it maybe too far away from the pump? When I ran the pump with 3 of the returns plugged up, I only ran it like that for maybe 1 or 2 minutes - should I run it much longer than that to confirm that any clogs/debris/air get pushed out of the line?
I'm stumped on what to do next.
-Mark-
-Mark-
