Thanks! Its a 8 ft long wire. 18 gauge wire. Maybe ill try it with 22. Im getting error AFS (which to my knowledge is blower motor not working, which it is), and when i discount the wire to the omni board and connect the firemans switch together it works. So maybe you gauge wire solution is what it needs.I’m not familiar with that type of heater. The yellow wire coming from the heater remote control contact has an inline fuse. Maybe check to see if that’s good? How long of a run is it on your comm wire from your heater to your Omni and what gauge wire? One weird time I had a long run and used like 18 gauge wire and had a similar issue and just replaced it with a 22 gauge wire and it worked.
