LCD has sections that work and some that don’t, so it’s hard to make out the current or set temp. It can be done simply by going +-10 degrees or to max and counting down. Anyway, how do I fix this? Does a membrane replacement fix this or do I have to replace something else? Everything works fine, just LCD screwed up and only working partially. Thanks in advance.
