Finally, after a few years, there is enough of white calcium (i'm assuming) buildup on my rocks at the waterfall. It's not a ton, but enough that I'm tired of looking at it.
I've read on the forums to try 5:1 water and acid, so that's what I'll do. A couple of basic questions:
1) what type of gloves should i use?
2) do i let it sit on there for a while, or do i use a wire brush right after spraying?
3) can i spray liberally or do i need to be careful with the amount I spray on?
