Hello there!
Newer pool/home owner here who is methodically addressing what appears to be long-standing pool issues. I did a SLAM recently, following the directions on this site, and the pool water has never looked better. Thank you!
Another issue is that I’ve long believed the pool to have a leak. I did a bucket test a few days ago and confirmed the suspicion. The pool lost a couple inches more than the bucket.
I ordered some Anderson dye to perform a leak detection and determined that I have a leak in the passive (not hooked up to the pump at all) pipe running from the pool to the spa. The dye was being sucked into the pipe from the pool and spa side.
In retrospect, it makes sense that there is a leak there. A previous owner built a room over the spa and there’s a large wall right over where the pipe runs. My hunch is that the weight broke the pipe.
Good thing we passed on the pool inspection!
Anyway, my question is: Is there any reason that I shouldn’t plug both ends of the pipe?
I really appreciate the help! I can add photos if necessary.
