Installed pool last season. Trying to install offline chlorinator. Kit came with fittings and tubing, but I will not use the saddle clamp fittings. I have installed appropriate tees in place so I can use threaded fittings. Chlorinator came with tubing that is non-standard, so I want to simply buy the tubing and fittings I need.
Need 3/8" OD
What is UV resistant, and suitable with chlorinated water, that is available in small rolls (15-20'?
What have you used other than the "Hayward replacement" that seems to be only out there in overpriced 8' lengths?
TIA!
Need 3/8" OD
TIA!
