Do just as @wireform instructed.
Just wanted to add that at higher levels of ta the decrease from each dose of acid isn’t as much as it would be at lower ta levels.
You’ve got plenty of room for ta to come down before it’s a problem so don’t worry about it.
Don’t get discouraged- follow the test instructions & poolmath.
Also add acid directly to the tub vs diluting it (there’s less chance of splashing/spilling it this way)
Hold the measuring cup over the water, pour acid into the cup, set ma bottle down & cap it, pour cup in water & rinse it out.
*Always add acid to water - never add water to acid.
U can do this!![]()
Am I supposed to run the aerators?
