- Jun 1, 2018
- 16,052
- Vinyl
- Hayward Aqua Rite (T-15)
its likely actually all cc due to the fact u added mps (which is an oxidizer not a sanitizer) & it reads as cc on a test.
Chlorine is both an oxidizer & a sanitizer which eliminates the need for mps.
Spa perfect is basically a clarifier - no sanitizing properties.
Protect 2 is a stain & scale preventer & will do nothing to clear up the tub unless you have a metal’s problem which you would deal with after you deal with the sanitation issue.
Please don’t add anymore pool store potions
Add 10ppm of bleach/liquid chlorine & The amount of Ahhsome necessary as listed on the container then purge. Scoop the funky foam out as it comes & wipe the waterline.
Drain, rinse, & refill.
Add enough dichlor to reach 10ppm fc.
After 30 minutes or so check that the ph is in the 7’s with your drop test.
Here’s the dichlor & bleach available @ Walmart in the states
- the important part is the ingredients not the brand.
For bleach it doesn’t matter the concentration so long as you put what % u have in PoolMath. If your bleach doesn’t contain cloromax, fabric enhancers, flavors or something to make it splashless it’s fine. Usually the cheaper household bleaches are the plainest.
To maintain your hot tub you basically need -
A Test kit
A purge product (Ahhsome)
chlorine (dichlor & bleach)
Muriatic acid or dry acid
Those other things u listed are unnecessary.
