Anytime my pool starts up in the morning the gauge reads ~34
I've eliminated the following as possible culprits
1.) changed out the gauge
2.) changed out the 4 cartridges
3.) checked to make sure every valve is functioning properly
What has seemed to work is turning off the system, diverting the water along a different channel (for example, opening up the solar valve) and then turning the system back on again.
When I do this the psi drops from 34 to 16 and stays there for the rest of the day, even if I shut the solar valve back off. Sometimes I can get the same effect by shutting off the system, opening the strainer basket, closing it,
and restarting the system. The following morning the psi will read 34 again
I suspect my motor/pump is at fault at this point
Some info about my pool:
Pentair whisperflow flow 2hp pump and 2hp motor
Pentair 420 filter
17,000 gallons and 2 inch plumbing
Thanks for any help
Pentair 420 filter
Thanks for any help
