- Jun 24, 2021
- 17,300
- Vinyl
- CircuPool RJ-60 Plus
Sure can. Thanks!Can you see the bottom of the deep end? Yes? Go swim. Safe up to and including SLAM level FC.
Sure, but needs to be run 30 minutes before testing in the morning...and your test needs to be before sunrise (6:22am)...so pump on by 5:52...OCLT directions say to make sure that the pump is running for 30min before testing. So its OK to be off overnight?
Doesn't usually, but can. Would be good to get a baseline OCLT, even with the rains.Also, big rain expected tonight. Will that impact things?
Those bowls can be algae breeding grounds.
Does chlorinated water flow through the bowls from sunrise to sunset?
I think you may find chlorine rapidly disappears when the water sits still in the bowls. That lets algae take hold.No. They get water flow for ~1/2 the main pump runtime.
I scrubbed them out several times using straight bleach.
The far right circle you noted is a floating basketball hoop
They do collect sand though.
