You can maybe test that idea by turning the bowls and spa spillover off for a day and see if you pass OCLT.
That inch of water is a perfect algae breeding ground thst gets dumped into the pool when the water starts flowing.Maybe an inch sits in the bowls.
Better to run the bowls continuously during daylight.You can maybe test that idea by turning the bowls and spa spillover off for a day and see if you pass OCLT.
No. Run the spa overflow for 20 minutes twice a day in the morning and early afternoon to keep it chlorinated.If the bowls are algae factories, does this mean that the spa overflow has to run full time during sunlight?
They are a rounding error in your FC loss.Maybe related, maybe not?
Went out and found a bunch of these dudes floating in the pool. Scooped them out and killed them.
