Rattus Suffocatus
- Jun 5, 2019
- 1,713
- Plaster
- CircuPool Universal40
Okay.. let's see if this works: here is how tight that 6' is from the wall to the HVAC. You can look at the rest of my build thread there too. Sadly, most of the projects (like the second shed and cutting and putting rollers on the cover) are still not done since the end of October. We are looking forward to the water hitting at least 70F though so we can at least take quick swims without having to immediately run to the hot tub...
Okay.. It didn't work the way I wanted... but this will.. The link below is the build thread... I reattached the Bobcat picture to give you a literal picture of why it's more expensive to use a little backhoe rather than a bigger one. Like I said the guy was good.... The backhoe had to fit through here also, and there is a picture of them digging out the plumbing line to the equipment pad in the thread below:
www.troublefreepool.com
Continuation of an odyssey
Continued from the "introduce yourself thread". The pool was laid out on Friday and we will have the dig on Wednesday (of course moved from Tuesday). We saved a little more gravel. I calculated the volume to be about 14,500 gallons, so yes it's intentionally a small pool. PB thought 15k to...
