- Sep 3, 2018
- 1,340
- Pentair Intellichlor IC-40
Thank you! It looks great congrats on the progress!@JenniferMarie90 It's Stonescapes Aqua White micro pebble.
Be sure the power is fully removed from the Intellicenter then wire in the SWCG.Do we just turn everything off and unscrew the dummy and put in the real one?
We'll add the salt in Friday then.
I think one reason is that "the majority/nobody on TFP" just want it finished and don't really care about the details, so they don't think to involve you. Both my designer and builder said that I was the most involved owner they have ever had.I don't know WHY this guy is so sneaky. He did the same with pool chemicals, just said he was doing his thing, asked for details, and we're left clueless cause he wouldn't share.
Would you give me a ballpark on price of the mosaics? There is no place close to me, I'll have to order on the phone.@colleenbevans Thank you! I really like the mosaics. We had some in our last pool and wanted them again but didn't want to spend the money. My husband knew how much I wanted them so told me to go ahead. I'm so glad I did. I love these fusion glass ones. So pretty!
Where in Pool Math do I figure out how much salt to add? I switched our pool to be SWG instead of bleach but it's not giving me a target and I came find where to fix it.Be sure the power is fully removed from the Intellicenter then wire in the SWCG.
Have you added salt? If not, put in 2/3 rds what Poolmath calls for, mix it in well with the brush and let the pool circulate for a day. Test salinity. Add what is needed to get to ~3200 ppm salinity. Be sure the SWCG is OFF or not installed for this process.
Start the SWCG generating 2 ppm FC per day. Use Poolmath to determine the settings.
Your minimum RPM to close the flow switch for the SWCG is your base flow rate. Probably around 1400-1600 rpm. Once the SWCG is installed, run the pump at 1400 rpm, see if the flow switch is closed (SWCG Flow light Green). If so, that is your base rate. If not, increase by 100 rpm until the SWCG light is Green.
