Noticed this happening, how alarming is this?
Glina126
3
Austin, Texas
Hi all! I am fairly new to pool ownership and new to the forums. I had a 15x30 above ground pool (professionally) installed about 2 years ago. Everything was going smooth until I started noticing the bottom rails starting to bend upwards. Now I understand that I will probably have to have the pool dissembled and redone but I would love to know if I should take immediate action or if I am ok for the season (another 3 months). I measured the bars to be coming up about 1/2 inch above the rest of the liner. I do have small holes in the sand from stepping around, but the pool seems to be balanced within 1inch everywhere.
I will be contacting the installer, but I would love an independent review as much as possible as well. I have been trying to find someone local to come inspect but most of the guys I found deal with in-ground pools. I am in Leander, Texas if anyone has a good contact for anyone that could come out and inspect.
Looking forward to everyones thoughts. Thanks!
- Glina
I am not sure I understand what you’re referring to.
Do you mean the uprights (big plastic vertical posts)?
Can you take a pic from further back so we can see the orientation of the pool?
