Is there a way to know positively that chlorine is bring generated? My aquapure 1400 recently was showing that it needed attention ( cleaning) by the code. Upon inspection, there was definitely calcium buildup, so I cleaned it w muratic acid and all error codes went away and shows that it is flowing and generating. But ever since I have had inadequate chlorine levels. The stabilizer was low so I attended to that and raised it to 90. I’m running the pool 12 hrs per day at 100%( much more than I have the past 10 years) and I find within a few days my level has dropped from 6 ppm to 1-2. I’m presently adding liquid chlorine to keep it up. Pool is fine. Water is clear and about 80 degrees. I do show a small amount of algae in the pool if the chlorine drops but quickly resolves once I get the level up
Anyway, I’m about to order a new cell hoping this will resolve the issue. Any thoughts?
