Not getting a CYA reading
When testing PH, initial reading shows 7.4 but if I wait 5 mins, the color becomes darker and it then shows 8.0, which is the more accurate reading?
Cya now shows 70, I used one 10 lb bag but it’s up because I had used plenty of trichlor tabs while waiting 4 days for the delivery of cya
Marty - Pool is roughly 70% clear - it’s day 10 of SLAM and I feel the whole process is moving way too slow. Is there anything else I can do? FC shows 28, CYA shows 70-80, I’ve got the SWG set at 100%. There are no leaves or debris in the pool, I can see bottom of the deep end. Each day it only improves slightly.
I will do that for sure today, I was thinking the same since there is no longer a need for me to backwash as I did in the first few days.
You still backwash once filter pressure rises by 25% over clean pressure. This may happen quickly. Repeat adding DE.
Pool is sparkling blue now finally - that took a solid two -three weeks. I cleared roughly a 33 gallon trash container amount of leaves during this process from the deep end, I’m guessing they were what was contributing mostly to the algae buildup. Any way, just wanted to say thanks for the guidance.
