- Jan 9, 2021
- 135
- Plaster
- Hayward Aqua Rite (T-15)
Here is my current flow rate
What is the flow rate when the suction valve is set for pool and return valve set for spa? 55GPM
I am having a hard time understanding what you are writing
What could be wrong with the filter so maybe I can fix it , valve maybe ?The check valve will not open all the way if the flow rate is too low. It will only open fully when the flow rate is very high. So if you see the check valve opening a little and it is fairly easy to open by hand, then it is likely working ok.
