Looking to add SWG to my 32K GA inground pool - probably Circupool Universal 55.
I've got a power limitation because everything is 110V. I can't support the required SWG amperage when my two-speed pump is on high. (Pulling new wires is not feasible either.)
At low setting, I'm probably getting 12-15GPM, but Circupool specifies 20GPM minimum.
Has anyone run this at lower GPM? Does it work?
Has anyone tried modifying the flow switch so it triggers at low flow?
Any danger in actually running the SWG at 15 GPM? I wouldn't think so but looking for info...
Thanks
Thanks
