My water is nearing the end of its life cycle, (based on my current TDS reading being about 1300ppm higher than it was at startup). What I’ve noticed with this first fill using the Dichlor/Bleach method is that initially I had some expected CC immediately after a soak (~0.4ppm) which was pretty much gone the next day as anticipated. But... over time, a base CC level slowly creeped up as the weeks passed and it stopped going back to 0ppm after dosing with liquid chlorine. I’m almost 4 months in on this fill and the CC stays around 0.6ppm and won’t drop any lower even with a superchlorination above 12ppm or a shock and sustain of a few days. I’ve even kept the cover off on a bright sunny day for hours and that ate up my FC but didn’t drop my CC below 0.6ppm.
Only thing that makes sense to me is that the CC that’s registering on my K2006 kit isn’t the same as CC that’s able to be broken apart with FC greater than Breakpoint. Is this normal and able to be explained?
