Yesterday it ran fine, so I don't think it is the DE filter needing to be backwashed. Because there isn't suction for either the skimmer or cleaner, I don't think it is something specific to either of those lines, as the other line would still work if there was a problem with one. There has been a bit of dampness for a little while around the base of the pump. It hasn't been much, so I haven't looked into it much or done anything. If it is a seal issue and the fittings need to be replaced, how involved is that as far as cost and time/difficulty? The pump is pretty old, so I have been thinking of replacing it with a variable speed pump at some point.
