Hey everyone!
So my friend down the street asked me to test his pool. He's been using a pool company for the last 10years. You can see the test results as no stabilizer or chlorine! (Mike's Pool) The water is clear. He has a feeder system that uses stabilized chlorine pucks and it's full of oucks.. It is a Hayward Chlorine Feeder. I noticed the dial is set to 2. The dial goes from 0-8. I put 4 scoops of DPD powder and the water sample didn't change colour. Also the CYA test showed 0 (filled the whole tube and you can see the black dot clear as day). It's a real head scratcher, as I would assume there has to be some CYA in the pool because he's using the pucks that have CYA in them. Thoughts?
