The reading for the water temp (the one in the pipe between pump and filter) disappeared on my Mobletouch2. I ordered a replacement sensor. That didn't help. The replacement is simple - can't see that I did anything wrong. The casing on the probe on the old sensor was cracked in a few places so I though it made sense that I needed a new one. I checked the resistance of the new sensor before connecting (8340 ohms) and the voltage after connecting (2.22 V). The display is still blank. It seems that there should be a water temp field on the display reading zero or something if it was just the sensor. Now I wonder if there is an issue with the card in the Mobiletouch RF controller mounted by the equipment or with the Mobiletouch? Any suggestions? Thanks.
