I bought a home in Tuscon with a 8000 gallon in ground pool exactly 1 year ago. I've had issues since day one.
Timer = Intermatic 104 for 240V. Pump = Centurion 1081 3/4 HP 230/115 SF 1.65 HZ60 Amps SF 7.1/14.2 RPM 3450.
Distance Breaker Box to Timer = 45'
Distance Timer to Pump = 2'
Yesterday I decided to test everything, with a Klein multimeter, working my way from the breaker box to the pump.
- Breaker Box - Yesterday & today both 15 AMP breakers read 120V @ ON position. Consistent. Checked several times with a multimeter
- Intermatic Timer - Yesterday Legs 1, 2 ,3 & 4 read 80V but it was dead quiet, no movement at all by gears or clock. Last night and today all legs consistently read 0V
- Pump Wiring at rear door - Yesterday both wires read 80V. Last night and today both consistently read 0V
- Capacitor - Removed and checked it today with a multimeter. Nothing. Dead
History
Pump stopped working 3 months ago so I put in a new capacitor. Yes I went up in Volts from a PRC30A to Titan HD PRC40A MFD+-5% 370 VAC 60/50HZ Protected @ 10000. 2 months later the pump got really loud while running so I stopped turning it on. It was winter so it wasn't the end of the world. My pool man turned it on a month ago to vacuum the pool and that is when it stopped working.
Anyway, why is there zero power at the Timer and Pump? I took the Timer panel out and the gears look really crunched together and the ON/OFF switch is touching the gears. Like I said, yesterday when there was 80 V going into the timer I could not get any movement from the gears or clock. The manual ON/OFF switch moves freely left to right but does not power timer on.
Even with 80V of power going to the Timer and Pump nothing tuned on. No sound at all.
Any ideas?
History
Any ideas?
