I've searched through the forum without success.
I have a 9 year old Hayward 250hed natural gas pool heater who's control board recently went blank after trying to adjust the temperature.
I tested for voltage at the line side and have 28v on the load side of the transformer. I took the board out with no signs of discoloration or obvious failure. Cleaned with iso alcohol. But no success. Confirmed voltage at wire harness.
Ended up grabbing a new board but still no go. No lights.
I've checked for continuity across all the sensors.
Am I missing something? Could it be that the transformer can put out volts but no current?
Or is it expecting another input voltage from some other source.
From what I can tell from the schematic the board simply checks to make sure the failsafe are good. Sends 6v to the the gas valve to open it and the ignights.
Really need to get this fixed.
Thanks in advance.
Thanks in advance.
