I recently had to move the pool plumbing for my pool. 16’6x36’6 inground. Everything was disconnected and moved. Now the swg only reads water temp. Everything else says 0 including salinity. The housing and board werent moved, just the cell and flow switch. When i turn it on i don’t get the light for flow to turn on either. Only the “on” and running or superchlorinate lights work but it is not generating. The knob can be adjusted for percentage but it still says 0%. I checked the solders on board with no luck. If it was the cell, wouldnt the flow light work? Its odd that all the sudden it wont read flow or anything else or tell me that the pump is off.
It’s a pureline 7707 i believe. T-15 cell
