No Algae but the water is milky cloudy
Thanks for replying. I am new to this. It started out being greenish color. So I put algaecide and vacuum the the next day. Now it turned from green to a milky color afte shocking the pool 3x.
Chlorine level read almost 0 ph 7.0 alk 80.
Welcome to the forum!
You need to follow the SLAM Process. To do that, you need a proper test kit. I suggest the TF-100 A proper test kit is needed to get the accurate water chemistry results needed to follow the TFP protocols.
While you are waiting on your test kit, add 5 ppm FC worth of liquid chlorine / plain bleach to your pool each evening with the pump running. This will replenish the FC lost each day to the sun and also inhibit any algae in the water from growing further.
I suggest you read ABC's of Pool Water Chemistry.
Welcome! :wave:
You've still got algae. The majority of it may be dead and waiting to be filtered out, but it's there. And unless you keep the chlorine level up it'll come back with a vengeance and go green again. Avoid the urge to use floc or clarifiers. If you want to know why not, use the search box up top and look for threads with "floc" in the title.
You need the SLAM Process
If you prefer the movie to the book,
