- May 3, 2014
- 58,721
- Fiberglass
- Pentair Intellichlor IC-40
In Poolmath you select Boric acid and it will tell you how much to add to achieve the level you wish.
Essentially none. A tenth or so drop in pH, at most.What kind of Ph spike can I expect with this?
I think I should SLAM.
Do an OCLT tonight if you like to see if there is an issue.
Yes.ok, will do. Given my current chlorine level, should I add some now to do the test tonight? if so, should I add to get to within the recommended range of 5-7ppm?
I did notice a little mustard algae forming in the corners.
Does this give any clue about mfg. date?Add 5 ppm worth of liquid chlorine. Circulate pool for 30 minutes. Test FC. Sounds to me the liquid chlorine is weak.
Added 80 oz LC, which according to pool math should have brought me to 5ppm. Tested half hour later, test shows 2.4ppm. So either weak chlorine, or I did not test my CYA correctly, or a combination of both? I feel pretty confident about my CYA test showing 40, and it concurred with the pool store analysis of 39ppm. So seems weak bleach for starters, by 50%. Do you think I also think I need to SLAM, because of the recurring mustard algae?Add 5 ppm worth of liquid chlorine. Circulate pool for 30 minutes. Test FC. Sounds to me the liquid chlorine is weak.
