This is the first year that we have managed our saltwater pool ourselves so I have a few questions about our Bioguard Mineral Springs saltwater generator that I'm hoping someone can answer for me.
1. When you add salt to the pool, do you always have to wait 24 hours before turning the saltwater generator back on or does this only apply when you put in multiple bags of salt at once? I added 3 bags yesterday, and one more bag at noon today, so I was hoping to turn the SWG back on this evening if it would be safe to do so.
2. The panel on the SWG says we need to have a minimum salt level of 2600 but it doesn't say what the optimal level is. Will the SWG work okay if the level is 2800, or does it need to be higher than that in order to work efficiently?
3. What percentage level should I set the SWG on when I turn it on for the first time this season, and how often should I test the chlorine level to figure out what the optimal percentage level is?
4. Does the SWG need to be turned off when adding chemicals such as calcium increaser, shock, Ph reducer, alkalinity increaser, etc.
5. Is there any maintenance that needs to be done each year to the salt water system?
