- May 3, 2014
- 58,732
- Fiberglass
- Pentair Intellichlor IC-40
It might be 13%, but not much higher. The higher strength bleach degrades quite quickly.
These are awesome. It'll make your testing more accurate and more consistent.3)I have been manually stirring the power w the blue scooper. Is there a better way?
I get my sample at least 15 minutes after the filter has been running. I go elbow deep across from a return & rinse the sample bottle a couple times before getting the sample. You want to do the test fairly quickly because the solution will turn pink again if it sits too long. You should be able to complete the test in less than a minute after adding the powder. Bottom of the meniscus to 10 ml line.4)is there a best way to scoop the water? wondering if maybe i'm getting too much surface water vs deep.
