- Aug 12, 2021
- 37
- Plaster
- Autopilot Digital Nano+ PPC2
Hi all,
Fantastic resource you guys have here. Just wish I’d found it sooner.
I’m looking for some general feedback/advice as I am looking to move away from having my pool-guy take care of the pool and plan to take care of it myself. It’s been on my mind for a while but I found this forum via reddit as I had to recently replace the old dual speed motor after it died. Went with a variable speed replacement. Figured after learning how to and doing that, now is a good a time as any to make the switch. The pool guy cleans the pool once a week but I’m sure he is not doing most (any) of the tests I’ve seen on this site. I’ve quickly made the journey from “I’m sure my pool guys is taking care of all this” to “oh Crud, I really need to do this myself!”
I have read most of what I can find on the site/forum and it seems manageable, at least once you get comfortable with it. Seems a little daunting with all the “daily testing” talk though.
Plaster pool, ~13,000 gallons, including corner spa with spillover. Pentair Dorado suction side cleaner.
Still need to figure out what speed to run the new motor at but I’m sure I’ll need to test levels in order to know what is a good speed to maintain correct levels. Currently running it at 2350rpm / 2850rpm.
I have a SWG (Autopilot Digital Nano Plus). Cell looks clean but is probably 4/5 years old. Will need to add salt as the pool pump was down for about 4 weeks when I was finding time to install the new motor. Currently at 2400ppm. Should be ~3200ppm according to the manual. Again, I’m sure after testing properly I can determine if the cell needs replacing? Any other way?
Seems like the TF-Pro Salt or TF-100 Salt are the best kits. Any reason to spend the extra $65 on the Pro? Currently spending $120/month for the pool guy so I’m sure they are both worth it and will save me money after a few months. How often will I need to get new reagents?
Assuming the TF-PRO SALT is the way to go, a good first step would be to use the tests and PM app, as well as post results here to get any advice I guess. What else should I be doing between now and the end of the month when the pool guy will stop?
Lots of questions I know but lots to learn!
Thanks.
Thanks.
