Hello everyone. Let me first say that as frustrated as I feel I am equally as grateful for having found this amazing forum...been browsing for a month or so and learning so much but now I feel so overwhelmed that I had to post for help as I feel like I am losing our pool. Thank you in advance for any/all input!
So my quick story...3 months into being a new pool owner...zero prior experience. Pool is currently being balanced weekly by "pool guy". Purchased TF100 about 1 wk ago because pool is consistently getter worse, ie turning green, yellowish green stuff on walls and floors, cloudy and today all of the above plus "milky". Pool guy serviced the pool 4 days ago.
RESULTS from my TF100:
6/17/17
FC=9
PH=7.6
CC=0
TC=9
CYA=105
TA=160
CH=250
6/19/17
FC=6
PH=8
CC=.5
TC=6.5
CYA=125
TA=90
CH=275
Tomorrow, Tues 6/20 I plan on draining 50% of the pool to get CYA levels down to about 60, then I will drain & refill over the next few months to get down to the 30-ish level. As far as I can tell this pool has been using chlorinated tabs for years, needless to say those will not see my pool any longer and I will fill with liquid chlorine from here on out!
Ok so my questions are;
1. As I am draining the pool do I need to brush the walls? Or is it ok just to drain? Or do I vacuum before draining? Pool is presently slightly green, cloudy, dull, milky w/a little yellowish green on walls/floor but not much.
2. When I refill do I add liquid chlorine while filling? Or after its been filled?
3. Do I add liquid chlorine according to new CYA level or do I have to SLAM pool once filled?
My thought was to add liquid chlorine to pool at beginning of re-fill at projected CYA level of 60 so that it can begin to do its thing while pool is filling with fresh water (which I tested btw and has 0 CYA). That would be approx 8ppm, and then once pool is filled I would test again, jump on pool math, and begin balancing pool accordingly and then go into "maintain" mode.
4. Am I missing something? Some step or steps?
5. Do I have to SLAM at some point? or not because of the 50% new water?
6. Do I just go into maintenance mode after the refill if everything tests ok?
7. What about the yellowish green stuff will it go away with the new water and lower CYA level? and appropriate FC level?
Again, sorry for all the questions.
TBH, I am a little scared, not so sure I can do this lol
JD
6/17/17
FC=9
PH=7.6
CC=0
TC=9
CYA=105
TA=160
CH=250
6/19/17
FC=6
PH=8
CC=.5
TC=6.5
CYA=125
TA=90
CH=275
JD
