Yea I was locked down with a bunch of murderers, rapist n pedophiles.Hang in there for a bit. It looks good to me but of course when you need the pros, Everybody is busy that day elsewhere.
Equipment looks good stringer.
The unibead looks cleaner and you wont have to fuss with adjustments during the fill, especially if there is a border on the overlap. You'll have to make sure its let down evenly all the way around the pool.
When we needed a new liner my husband did a search for the gauge and size liner we needed. He then picked out the one he liked then searched for the best price. It ended up being on ebay so easy to check their service!
I would not do the overlap for the reasons Casey gave.
We used a 3 port Jandy NeveLube when we isntalled the heater. You can view them here:
Never Lube Jandy Valve: Jandy Pro Series Valve | Jandy
Looking for a Never Lube Jandy Valve? Find this Jandy Pro Series Valve for the Perfect Pool Experience. Buy Now w/ a Pool Pro Near You!www.jandy.com
Absolutely Not!!!! These pumps and filters run with high pressure. It needs sent back for replacement. That is not a small crack and it looks used.Thanks. I will not be running a heater. I should go with a jandy 2 way valve, right?
Pump just came in the mail, and I noticed a small crack. Can I just throw some silicone in there?
