So, should I keep adding bleach until my bromine is 10ppm??? How much should I add each time and how long should I wait in between testing?
You have been "Pool Stored"! That means you have been given a line of BS that helps increase the store's profit margins. As far as it goes I work in a pool/spa supply as well as doing commercial pool/spa maintenance in the summer. There is no real advantage to using MPS over chlorine for shocking a bromine spa. Both oxidize the bromide into hypobromous acid and MPS can cause a pH drop and skin irritation in many people. It is also a high profit margin for most supply stores. (Most stores HATE us to use bleach because they don't sell bleach. Even those stores that sell liquid chlorine, which is exactly the same thing, will tell you bleach is bad! Totally nonsensical!) Another secret on MPS. It's made by Dupont under the name of Oxone. Doesn't matter whose you buy. It's all Dupont Oxone. They hold the patents and make the stuff. Everyone else just repackages it!SpaMedic21 said:Yes, I did use sodium bromine in it first then the tablets....
Anyways today I was really frustrated with the water so I took a sample to the spa store. Everything was in decent range except my pH was 8.0 and my calcium was 130ppm. Other than that everything is good.
We ended up getting into a discussion about what I am using to shock the water and I mentioned bleach and they bout flipped a gasket. Anyways, my hubby and I got tutored on spa chemicals and what not, and we were given free samples of powdered shock with potassium monosulfate... something along that line... to use instead of the bleach.
Well I did two treatments of the shock today and my water is nice and clear and the smell disappeared. I think for now I am going to stick with the store chemicals and once I get more into the hot tub lifestyle will one day try the BBB method. The guy was telling me that most the bleaches out there have salt bases and the bleach has been screwing with my alkalinity and not allowing it to activate my bromine to burn off the organics.
I tell ya what those, I am sticking to the Leisure Time line of products for now....
To determine the bromine levels you need to test the water.SpaMedic21 said:I forgot to ask...
How do you know when your bromine is below 10ppm... I take it you have to test or is there a certain time frame that you can usually just call it good and jump on in???
And bromine kills viruses, bacteria, algae?
SpaMedic21 said:The guy was telling me that most the bleaches out there have salt bases and the bleach has been screwing with my alkalinity and not allowing it to activate my bromine to burn off the organics.
