My pool is ~17 years old. 40,000 gallon, 20x40 with a SWG and heater. Two skimmers and a floor drain; three return jets plus a slide. We've always gotten good circulation and efficient cleaning through the plumbing.
Last year, the original pump went out. Our local pool company evaluated the plumbing and sized a new variable-speed pump (the original was not VS). Pool opening went fine, but the new VSP doesn't seem to create enough suction in the skimmers to clear the surface debris, even running at a max 3,400 RPM. I also notice much lower pressure on the filter than the previous pump (15 instead of what was typically 25). After several days, the water level is stable, so I don't think there's a leak in the lines.
Pool company suggested I try closing one of the skimmer valves or floor drain. If I close one of the skimmers AND the floor drain, the pressure increases to ~25 at the filter, and there is enough suction at the remaining skimmer to bring debris into the skimmer, but not down into the basket. Obviously, I'm not going to run the pool that way on a permanent basis.
Any suggestions?
Any suggestions?
