Hello, thank you for any assistance/advice. My IG pool was built in 2017. Last pre-summer swim season I struggled with high Cyanuric Acid levels and landed up draining pool and refilling. During this past winter I noted the chlorine levels staying high without adding tabs to deck chlorinator. Back to Leslie's and adding Chlorine Neutralizer and then NoPhos, then back for testing, then adding Alkalinity Up, back for testing, told today to add 14 oz Muriatic Acid . Each time I go in they tell me drain it because my TDS is 3700 (spoke to their district manager about some stuff and she said not to drain this season since I just drained it last season). Here are my current test results today:
FC 2.49
TC 2.64
pH 7.9
TA 116
CH 228
Cyanuric Acid 125
Phosphates 68
TDS 3700 (has been between 3100-3800 from 4/5/20 - 4/22/20).
I found this website today due to frustration over local pool stores seemingly giving different advice depending what day of the week it was and really feel with ordering a proper test kit as this site recommends, I can do this on my own and with the help of this site. I have read different things on TDS, some say its an issue some say don't worry about it. I just spent $300 on chemicals and am trying not to drain pool after all this because water is not cheap here. Are my numbers that bad that I need to rethink this for upcoming summer swim season. Thank you.
FC 2.49
TC 2.64
pH 7.9
TA 116
CH 228
Cyanuric Acid 125
Phosphates 68
