Hello all! I'm not new to the forum, as I used it in the past with a previous home that had a problem pool.
We just purchased a Sundance Cameo 880 series tub with a 370 gal capacity. It's got one of those clear ray uv bulbs also. I do not plan to use the pool store to rely on advice or chemical products, but they included a variety of items to begin with...
Sodium Dichlor-s-Triazinetrione dihydrate with 55.5% available chlorine.
Leisuretime Renew, potassium peroxymonosulfate 32%, 3.26% active oxygen.
Alkalinity plus, sodium hydrogen carbonate.
A floater called nature's pure, which I guess is some mineral system/ clarifier.
pH down, sodium bisulfate.
And some test strips which only check pH and Alkalinity.
So, it turns out I have a leak on one of the lower jets in which I will have to drain the tub so they can turn it on its side to fix this week. So, since i already get to start over, in reading about hottub advice here, looks like I should buy some of that Ahhsome and flush the tub, correct? After using it, do I drain it again? I want to buy a good water tester. Which one?
They tested my current water before I added anything...
FC .2 ppm, TC .35 ppm, combined. 14 ppm, pH 7.9, alkalinity 44 ppm, adjusted alkalinity? 42ppm, calcium hardness 8 ppm, cyanuric acid 5ppm, 0 iron and 0 copper.
We do have a house water softener. I'd imagine the water would be nearly the same after refill.
Probably more info than anyone might be asking, but any advice on how to get a good start? Thanks!
