Baby steps. I followed the instructions on how to test for PH. The color that appeared was 8.2. Then I had to add acid demand agent and count each drop and get the color i want associated with desired ph. I chose ph7.5 When I look at the chart there is the volume of water which is 21000 gallons. I counted 5 drops. Am I adding 1.75 qt (3drops) and 1.15 qt(2 drops) which equals 2.87 quarts. Is this correct?
If it is great but then I have another issuel
My alkanity is around 200ppm and on my kits chart says I need 1.60qt to bring it down however this is 10pm for desired change. I’m assuming this is for every 1.60qt I will bring down my alkalinity by 10pm. So if I use 2.87 qts of acid to bring down ph I will only bring down my alkalinity by 15ppm give it take? This is not fun.
Let me know
Let me know
