27,500 gallon in-ground vinyl SWG pool
Outside temp currently 74 degrees
Using TF-100 and K-1000
As of this morning:
Cl:>5
Br:>10
pH: 8.0
Salt Water: 3200 ppm
CYA:40
Chlorine:6 ppm
CC:0
TC: 6ppm
TA:110
I am confused about a couple of things.
What do I do with the Brokine reading?
How do I calculate free chlorine?
I realize pH is high and if I read correctly TA is high.
What should I do?
I’m attempting to take this task over from my husband. He typically takes a sample to Leslie’s. I’d prefer to do the calculations on my own. Just have to nail down the basics. Pool water is clear and clean visibly.
Thoughts/Suggestions/Advice?
Thank you.
As of this morning:
Cl:>5
Br:>10
pH: 8.0
CYA:40
Chlorine:6 ppm
CC:0
TC: 6ppm
TA:110
What should I do?
Thank you.
