Admittedly, my pool has been fairly easy to maintain...at least in my eyes...maybe not yours
. The pool store I purchased it from sold me on EZ Pool and the Nature 2 system. I've used both since I've owned the pool. I traditionally open the pool in Mid-May and close it down in early September (harder to keep warm plus the kids are in school at that point). Traditionally, it takes a scoop of EZ pool, a chlorine puck, and a vacuum / backwash each week. The water is crystal clear. I've used a cheap testing kit purchased on Amazon that checks Chlorine and PH only. I'm not sure it's even worth the $10 I spent on it
. At pool opening after filling, I've brought a water sample to the pool store and end up buying a couple hundred bucks in chemicals based on their directions (phosphates, ph stuff, shock, calcium, etc). EZ pool normally runs me about $100 and lasts the pool season. Two years ago I purchased a bunch of chlorine pucks from Costco, and they lasted two years. I think the cost was around $50?.
So...to the experts on this forum, I pose some questions....
Thanks
Rob
- What are your opinions on EZ Pool and Nature 2? They seem to have made maintenance easier...but this is the only way I know. Are the methods described on this site easier or more effective? I've read through many of the articles in "Pool School", and admittedly, it seems I'd have to monitor my pool's chemicals way more than I do now. It seems like a lot of work. Am I wrong?
- Cost wise, given the size of my pool and the length it's traditionally open, would I still save a good deal of money on chemical costs?
- Regarding opening the pool, after filling, vaccuming, and backwashing, it sounds like the first step is to take a water sample....to ensure the stablizer and ph are in good shape...before proceeding to shocking (SLAM). Is this correct? Shocking seems to be an ordeal. It sounds like I need to be around the pool for a good couple of days to ensure it's done right. This is much different than what I've done in the past...basically dissolving a bag of shock in water and dumping it in and letting the pump run all night. Can I post my results on this site or should I just use the "Pool Math" calculator?
- It's probably difficult to estimate, but any ideas what up front 'chemical' costs I'd be looking at? Between chlorine, ph up/down, alkalnity, stablizer....it seems like it would be no different than going to the pool store. I know I'd have to get a new test kit to do all this, so there's a new up front cost.
Thanks
Rob
