New to testing, new to Taylor K-2006
mknauss
37,016
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
OK -- tonight, add a gallon of 10%. Let the pump run for 45 minutes or so, and test the FC. Record that. In the morning, before the sun hits the pool surface, take a sample and test the FC. See what FC drop you get over night. That is what is called a Overnight Chlorine Loss Test
Reactions: Ericinphoenix
Ericinphoenix
52
Arizona
This evening's test, after adding a gallon of 10% and waiting 45 minutes was 3.6 ppm. Should i add more or should i wait for the predawn test?
mknauss
37,016
Laughlin, NV
Fiberglass
That is not even as much as a gallon of 10% will add to the pool. I wonder if this chlorine is weak.
If possible, add another gallon if you have it. Let pump run another 45 minutes (brushing really helps) and test again.
Ericinphoenix
52
Arizona
So, after adding another gallon last night, my predawn test shows 6ppm. Does this sound good? Also, i am leaving for a few days. Should i let the pool be, or leave a floater with some tablets inside?
mknauss
37,016
Laughlin, NV
Fiberglass
Did you test again last night after adding the chlorine?
All you can do is use a few tablets in a floater if going away.
That is when a SWCG is so much better to have.
mknauss
37,016
Laughlin, NV
Fiberglass
OK -- the 'about' is not great when it comes to testing. But sounds like you did not lose any overnight. But there is no way that chlorine is full strength as each gallon should add just over 4 ppm FC. And it does not sound like it is.
Ericinphoenix
52
Arizona
Plan to locate HASA next week. This was from Home Depot. Never handled the stuff before, expected to be a strong aroma. But upon opening each bottle, there was barely anything to smell.
Ericinphoenix
52
Arizona
Hello. So after being gone for a few days, and leaving a few tabs in a floater, i find the pool looking okay, but in need of brushing. I do the brushing, add 10% Home Depot liq chlorine, and run the pump for an hour. Then i test. It's at 3ppm. Does this still look like a case of weak chlorine, or am i overlooking something or doing something else wrong?
mknauss
37,016
Laughlin, NV
Fiberglass
Seems like weak chlorine.
Ericinphoenix
52
Arizona
Took the floater full of tabs out yesterday and added a gallon of 10% liq chlorine. Today's numbers:
FC: 5.8
PH: 8
TA: 170
CH: 450
cya: 40
How do these numbers look?
mknauss
37,016
Laughlin, NV
Fiberglass
Looks good. Follow the FC/CYA Chart for a 40 ppm CYA.
You can use a 10 ml water sample for the FAS-DPD test. Each drop to clear is 0.5 ppm FC.
Ericinphoenix
52
Arizona
here are a couple pics. Water just isn’t as clear as I’d hoped. What am I doing wrong? Or is it a question of time?
mknauss
37,016
Laughlin, NV
Fiberglass
I agree.
It may be time to just follow the SLAM Process. With a CYA of 40 ppm raise the FC to 16 ppm. Test FC several times per day and raise the FC back to 16 ppm. Brush daily. See if that clears it up.
mknauss
37,016
Laughlin, NV
Fiberglass
I think you should. Cloudy water is 99% of the time an organic issue that will resolve with more chlorine.
