New to testing, new to Taylor K-2006
Texas Splash
One gallon liq chlorine, 10%
Sure. One gallon should increase your FC by about 4 ppm. You might check again later this evening though. Your comment about the "the water looks alright, a little cloudy" concerns me. I hope the FC was;'t too low for too long already. So this evening if the FC is down to 3 ppm, I'd add another gallon. Marty might even recommend you perform an Overnight Chlorine Loss Test.
mknauss
36,021
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Good job. As you put the chlorine in yesterday with 0 CYA in the water, it was going to be pretty much gone. So now follow the FC/CYA Chart, based on the 40 ppm CYA you added to the water. No need to test CYA for a week or so.
Target the upper range for that CYA for your FC each day. Which is 7 ppm FC. So when you test this evening, add enough liquid chlorine to get to 7 ppm from the level the water is when you test it.
Use a 10 ml water sample for your FC testing. One scoop of powder, Each drop of reagent equals 0,5 ppm FC.
Ericinphoenix
52
Arizona
So after adding a gallon of liq chlorine 10% at 1030 this morning, i just tested it at 430 pm. It took four drops into the 10ml sample to achieve clarity. So if i understand clearly, i then should multiply 4 x .5, which equals 2 ppm? Is that correct? If so, should i add more liq chlorine stat?
mknauss
36,021
Laughlin, NV
Fiberglass
OK -- you are correct. Add one gallon of 10%. That gives you 4.3 ppm FC plus the 2 ppm you have now.
Test the FC again tomorrow at about the same time.
Have you added all the CYA yet?
Ericinphoenix
52
Arizona
Yes, all the CYA via knee-high hosiery was finished this morning, 8lbs, as prescribed. I have two pounds left over. Should i use it or wait?
mknauss
36,021
Laughlin, NV
Fiberglass
Wait. Test the CYA level on Wednesday.
Ericinphoenix
52
Arizona
Tested this morning, just to see. I can see the bottom, 9ft down, but there is a slight haze. Anyway, it was 3ppm, 6 drops at 10ml. Should i go ahead and add more liq chlorine or wait to test this evening?
Ericinphoenix
52
Arizona
OK, so now it's up to 4ppm. But after 5 drops of the R-0003 DPD reagent, it's still clear, meaning no combined chlorine? Should there be? Have i made a terrible mistake? And since the FC is only 4ppm, should i add yet another gallon of 10%? Thank you!
bryanq480
64
tempe, az
hey if I am doing the 10 ml water sample/ .5 ppm per drop, I would still use two small scoops of powder correct?
mknauss
36,021
Laughlin, NV
Fiberglass
No CC is a good thing. You should target 7 ppm FC and a gallon of 10% will get you to 8 ppm. So that is good.
I was hoping to see your FC loss per day slow down. Once you test your CYA level tomorrow we can evaluate where you are at.
Reactions: Ericinphoenix
Ericinphoenix
52
Arizona
So here are this morning's numbers:
FC: 4.6
PH: 7.4
Tot Alk: 160
CH: after 5 drops solution turns pink, not red. That being said: 300 CH
CYA: past 40, halfway up to 30. Don't know what that number would be.
Does that TA mean big trouble? And what of the other numbers, ok? What should i do now? Thanks!
mknauss
36,021
Laughlin, NV
Fiberglass
Great. CYA is 40 ppm, what you added. Leave it.
The TA is high but will come down over time. No issue. You need the test result for Poolmath when your pH reaches 8 and it is time to add some acid.
FC still seems to be coming down a bit more than it should. How does the water look?
