I wanted to first off give my hats off to those of you out there guiding us all...
I have been on the forum for a while, and asked for some help when I first took over this home with a pool... the valves were very confusing...
that has since been figured out with the help of you guys here.
the Previous owner had a pool service maintaining the pool, so I kept them on the past few months and now have decided to take over the duties after studying up and reading the various info here on the site.
the pool has been maintained up till now by the pool guy using (pucks in the skimmer) he came weekly and managed the water (pool is clear, yet does have some scale build up on the tiles in areas where the water splashes around) mostly where the water overflow is at the spa
I purchased the Taylor 2006 kit and did my first test today
below are the numbers (granted my first attempt at testing) so I am hoping I did them correctly
outside temp is around 60 degrees, water temp is in the upper 50's to low 60's
Free Chlorine - 12ppm (combined chlorine showed 0)
PH - 7.6
CYA - 110
Total alkalinity - 200
Calcium hardness - 800
my question is
are these numbers well in line?
Free Chlorine seems high
we use our Spa about 2-3 times per week
I really just want to make sure I start off the right way and undue any damage that the pool guy did by using pucks vs the BBB method, which I feel would be better long term for water balance
thanks for any input and advice
PH - 7.6
CYA - 110
my question is
