- Jun 24, 2021
- 15,880
- Vinyl
- CircuPool RJ-60 Plus
When the truck fills the pool, add chlorine, pour in front of a return slowly with the pump running.I figure there should be enough flow to sufficiently mix it in at that point?
Add 5ppm of liquid chlorine.
4 hours pumping then test. You can run high speed if you want..
