New to owning pool numbers are concerning me please help
JoeSelf
745
Glassboro, NJ
Yes, Liquid Gold. Safe if you can see the entire bottom, At or below SLAM level.
You can let go for a while while swimming, but get it right back up as soon as you are out.
mknauss
33,936
Laughlin, NV
Correct. Once you know your CYA, no need to test it unless you have significant water exchange. Focus on FC during the SLAM.
Texas Splash
Squeeze those socks often as well. When I add a sock with about 2 lbs of stabilizer, I can let it pre-soak near a return for about 20 minutes then I squeeze it all out in about 15 minutes. But by the end of this evening you should have the sock all expressed and empty.`
