- Aug 7, 2021
- 33
- Vinyl
- Hayward Aqua Rite (T-15)
unfortunately it’s hard to find good “help”. I had a highly recommended company put in a Hayward VSP and SWG yesterday. They did by sending a guy that barely spoke English.
He put in about 8 40lb bags, told me to let the pump run and then in the morning to turn on the SWG.
I followed the instructions but the SWG said low salt.
I called the company because the jets etc are barely running and the salt level. I asked if I should crank it up to a higher RPM and they said no and to Use the default. The default results in no flow to the SWG.
Then they told me to add two more bags. I did and then it read is High Salt.
I cranked the the RPM for about an hour or two and now it’s generating.
First screen says 2900. Then shows “-3000”. So now I assume that doesn’t mean negative. But the current level is 3000.
All this to say WTH??
Pretty sure the set RPM 1725, is barely doing anything. This normal? Should I just set it how I feel? Crud costs too much money for bad customer service.
I’d appreciate any advice or suggestions from you kind folk.
